Wednesday
When I selected this plan for coming renewal, the 500 mins international call was not there
Wednesday
You’re good. I swapped from the $35 Can-US-Mex to the same price with the 500 min/mo int’l with the same price point. It doesn’t show up there but I did log in on pc and see it there.
Wednesday
HI @EdwinT
maybe just it didn't show clearly. Try go to My Account or use the app, on the Overview page, click Usage Breakdown and check if you see "## LD mintues 7 countires" if it is there, then you have the LD minutes
if not, then ask support agent to help
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
