01-30-2025
11:36 AM
01-30-2025
11:56 AM
computergeek541
I have the International plan with Canada/US and Mexico but am unable to connect to my banks 1866 number for assistance. I can make other calls to family in Canada. I also am unable to check my voice call messages. Anyone know how to fix this issue? @
01-30-2025 12:23 PM
@alegator_23 wrote:hi @Sol3
Interesting if it will work, as according to replies maybe it will not work, but looks like it's some kind of common problem with calls from Mex -> CAN
In Mexico, change the numbers to get your call through:
- Change 1-800 to 001-880
- Change 1-888 to 001-881
- Change 1-877 to 001-882
- Change 1-866 to 001-883
- Change 1-855 to 001-884
Also try what was suggested by @computergeek541 and @hairbag1 and let us know, as it's something that everyone may run into while in Mexico.
Best,
Hope it helps.
That would be interesting and will have learned something if that works. The reason that I believe that +1883 instead of +1866 wouldn't work is because of how there is no exit code there and I believe that it would be dialed just as country code of 1 and then the area code of 883.
01-30-2025 12:07 PM
hi @Sol3
Best,
Hope it helps.
01-30-2025 12:01 PM
01-30-2025 11:59 AM
@Sol3 wrote:I have the International plan with Canada/US and Mexico but am unable to connect to my banks 1866 number for assistance. I can make other calls to family in Canada. I also am unable to check my voice call messages. Anyone know how to fix this issue? @
Some toll free numbers only work if you're calling from a specific location. I would suggest calling the non-toll-free number of your bank. This is often provided on the back of your bank cards and credit cards.
01-30-2025 11:40 AM
try +1 883 instead of 866.
