03-27-2025 11:06 AM
Hi there,
I have the Canada-US-Mexico plan and I was looking at the fine print. It says I'll be charged for calls made within the US to US numbers. Is that correct? Does that apply to both local and long distance?
Thanks!
03-27-2025 11:13 AM
@Andrew145 Public Mobile is prepaid so there are never any extra charges. If something isn't paid in advance it simply won't work. So you can call to from and within any of the three countries, the only caveat being that to work in the USA you must have a Public Mobile approved VoLTE phone.
03-27-2025 11:09 AM
If you have Can-US-Mex plan then you r phone will work in all 3 countries and you can call any of them from any of them. No Extra charges.
