03-27-2025 10:58 AM - edited 03-27-2025 11:00 AM
So I signed up last night 4 accounts on the $35 65GB plans, it says that I get the 3rd month free when I signed up. When I logged in today it showed that I could upgrade my plan to the $35 75GB plan on the next cycle.
Does anyone know if this affects my 3rd month free if I change plans before that 3rd month?
Thanks!
Plans
03-27-2025 11:10 AM
Thank you, that's what I thought, the other 10Gb isn't required so I will wait and see if it's still available after the 3rd month.
03-27-2025 11:02 AM
03-27-2025 11:02 AM
Yes, if you signed up for one plan and change to something else beforethe 3 months expire, it will void or cancel all previous offers/ promotions.
03-27-2025 11:00 AM
pretty sure you have to stay on the same plan for the 3rd month free
but you can ask PM to confirm before you make the change.
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
