04-02-2025 11:14 AM
I recently got my plan, but when I make a call, I do not hear anything until the person I am calling says Hello. I do not hear any ringing, I can't even tell if the phone is actually dialing, until the other person answers.
I've never had this happen on any cell provider I've previously used.
Any ideas how to fix??
Thank you.
04-02-2025 12:57 PM
I don't have another cell phone, but as soon as I have access to one I will definitely try this. It's just odd, I never had this issue when I was on the Virgin network. Only thing I did, was put a different SIM card in. No settings were ever changed.
04-02-2025 11:50 AM
to eliminate hardware issues..can you try your PM sim in a different cellphone...see if that makes any difference. (Ignore this suggestion if you're using esim)
04-02-2025 11:24 AM
I have reset my network settings on my phone. The call will go through and the person I'm calling will answer, but from the time I press send until the time I hear "hello", I have no idea if the call is actually going through. I hear nothing.
I've googled and this is what I found......
That's why it's a pain. I have no idea if the call is actually going through or not. I have sent a message to the CS agent. So far I haven't heard anything back. 😞
04-02-2025 11:18 AM
this is a very common complain lately. I think it could be a Public mobile problem. But make sure your OS is updated, try Reset network settings. And report to PM and see if they can do anything
To open ticket, just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
