automatically renew add on when minutes are spent
thierrybrionne
how do i SET MY Add-Ons 300 International Long Distance Minutes TO RENEW AUTOMATICALLY WHEN MINUTES ARE SPENT?
7 REPLIES 7
thierrybrionne
Thanks for your feedback.
thierrybrionne
Thanks for the response.
JL9
Definitely an intuitive option that would be helpful for many but the no frills option won't have things like that unfortunately
HI @thierrybrionne   You cannot.  PM is prepaid.  The good thing is you need to buy first and you have full control of what you need.  You won't accidentally use more.  But the bad thing is you have to buy ahead and what you suggest cannot be done  😞
You need to actively monitory your usual and buy a new set when it is close to being used up
You can’t.
Here is what I do.
Know your average use per month.
I  buy 2 or more add ons
I set a minimum limit, at which you will buy more
When minutes drop to the minimum, I buy another add on.
Requires frequent checks or less often checks, based on the the “minimum” you set.
iliketotalk
@thierrybrionne unfortunately that's not possible but you can buy more than one at a time so you don't run out in the middle of a call
dust2dust
You can't. You need to manually buy them again.
Adding - but you can stack them. Buy 2 and have a total of 600 minutes. etc.
lol iliketotalk beat me to my edit.
