02-01-2023 10:42 PM
I need my account number to change providers. How do I get this?
02-02-2023 08:40 AM
@Mare2 Log in here https://telusidentity.telus.com/as/authorization.oauth2?response_type=code&client_id=cc26d3b9-3370-4...
with you email and pass you used to activate SIM card if you had it activated in store you will need supports assist ace to creat account if never done before
Watch for reply top of page to the
Right ( envelope image )
02-02-2023 08:39 AM
@Mare2 wrote:How do I log into my account. What is the address ?
login here:
https://selfserve.publicmobile.ca/
login id would be the email address
if you have forgotten the email address used, first try to use the Reset Password link there, enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
02-02-2023 08:37 AM
02-02-2023 08:36 AM
How do i log into self serve?
02-01-2023 11:31 PM
@Mare2 wrote:I need my account number to change providers. How do I get this?
That's not needed. IMEI number or PIN could be use if you don't have account number.
02-01-2023 11:04 PM
@Mare2 Log into self serve and go to profile tab
for you account number
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
02-01-2023 10:48 PM
@Mare2 login to My Account, profile page, and the account number is there
https://selfserve.publicmobile.ca/en/account/my-profile
02-01-2023 10:48 PM
Log in to your account, go to the profile tab and hover or tap the account number.
