03-18-2024
12:15 PM
03-18-2024
03:32 PM
computergeek541
03-18-2024 01:17 PM
another option is to use WhatsApp...the folks you want to talk / text with must also be WhatsApp'ers for this to work. What'sApp will use your local wifi whilst in Mx so no cost to you.
03-18-2024 12:21 PM
@Ashley16 as you know by now, no PM service in Mexico,
you can buy travel esim if your phone has esim, a popular choice is airalo.com
or you can stay with traditional travel sim card, one of the choices is Telcel
03-18-2024 12:16 PM
@Ashley16 No sorry PM only has roaming in the US with roaming add on , your best to get local pre paid sim card in Mexico for your trip
03-18-2024 12:16 PM
HI @Ashley16
No, it won't . PM does not have roaming service in Mexico. Use local data sim or esim instead
03-18-2024 12:16 PM
nope...only in Canada or US. You could try TextNow using local wifi.
