will a xiaomi Poco X3 Pro work on this network
mudmama
G_Pomzz
I have a POCO X4 and it works fine. As long as it's the Global version it will cover all the popular North American bands.
Shan_Bhai
Yes it works
Meow
As long as phone supports PM's frequencies/bands it should work.
Ideally, if you can borrow PM's SIM from somebody else and stick it into phone, that is the best test and confirmation.
@mudmama   What exact model number?  that would help to determine if the phone is international version or India variant.
Here are the 3G and 4G bands on this phone:
3G bandsInternational and India:  HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G bandsInternational: 1, 2, 3, 4, 5, 7, 8, 20, 28, 38, 40, 41 -
 India: 1, 2, 3, 5, 8, 38, 40, 41 -
the BOLD bands above are the compatible ones
Overall both international and India variant will work.  No difference on Voice for both versions,  BUT for Mobile Data,  India variant might not work well and might not connect in some area.
Any phone you are considering should ideally have 3G B2, B5 and LTE B4 (or B66 instead of B4), B12 (or B17 instead of B12) for minimum coverage.  (So, the International version meets the minimum requirement but not the India variant )
VIP_Tech
Hi @mudmama
Yes will working with PM,
HI @mudmama
It might work, but it might not work great depends on the version you have.
FYI, these are the bands used in PM
4G = B2 (1900), B4/B66 (2100 or 1700), B5 (850), B7 (2600), B12/B17 (700), B13 (700), B29 (700-Suppl. DL), B30 (2300)
3G = B2(1900) B5 (850)
