Issue regarding Network
MeghaP
Hello
I just got the public mobile network motörhead ago, but J am facing so many connection and service issues. I moved to other network and I paid for the whole month which I used just for 2 day, I want to request refund for remaining period. How can I do that ?
Immune
With regards to refund other have given you suggestions - with regard to connection service it's obviously because your are in a weak PM reception area. In the past I did have major connection problems while I was with Rogers that forced me to switch to Bell that had a tower just a few KM from my home. In turn I have now switched to PM with great reception because Telus and Bell do share towers. I  read that Rogers also shares towers but no idea why I had the poor almost non existent connection problem with them..
@MeghaP  pm is pre paid service and usually no refunds . So best to use the service till day or two before next renewal to avoid losing money . Have you tried reboot the phone or reset network settings ? Can you try the SIM card in another phone if physical sim to test . Can also ask support to refresh your account / or try and ask for refund best of luck
send  a  private message   To CS_Agent
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
hI @MeghaP
PM is prepaid provider and usually do not provide refund.  But you can try.
you can submit  ticket by direct message:
hairbag1
@MeghaP
no refunds with Public Mobile...or any prepaid service provider when you cancel early.
