11-13-2024 03:28 AM
I'm trying to use my UMIDIGI A15 smartphone as a Wi-Fi hotspot to connect my laptop (running Windows 10) to the net while I'm out, as my laptop doesn't have a SIM card. I set up my smartphone as a Wi-Fi access point, naming the SSID (network name) “A15.” However, the network doesn’t show up in the list of Wi-Fi networks on my laptop. Even when I try to manually create a connection to “A15” on my laptop, I get a message saying “Cannot connect.”
I haven't set up any blacklist on the phone, and adding the laptop's MAC address to a whitelist didn't work either. I've searched through previous posts here for a solution, but I haven't found anything that resolves the issue. Help, please!
Thanx!
11-14-2024 02:53 PM
hi @MarcoRossi I guess my suggestion helped a bit 🙂
your phone has the latest OS? maybe there is bug and hope a new OS update helps
did you also try to reach out Umidigi for support? and mtry also post on other forums. Not sure if Umidigi has one itself
11-14-2024 02:48 PM
Thank you for your continued support. I want to let you know something important
I've most recently discovered:
On my UMIDIGI phone, the default setting on the "Set up Wi-Fi hotspot" page has the
"Select AP band" option set to "2.4-GHz band." However, when I changed this to "5-GHz
band preferred," my laptop was finally able to detect the "A15" network. This probably
means it wasn't picking up the 2.4 GHz signal from my UMIDIGI phone at all.
But I don't want to just leave it at "Well, great, just use the 5 GHz band and problem solved!"
Here's why: my laptop's WLAN modem is compatible with the 2.4 GHz frequency, and, more
importantly, I can connect to other devices in my room, like my broadband router and other
non-UMIDIGI devices, on the 2.4 GHz band without any issues.
So, I'd appreciate it if you could continue helping me look into this.
11-14-2024 10:18 AM
yes, generally community member should reply in the open forum here for the benefit of others. Not sure why some members decide to private message you directly. Also I suggest you to ignore those messages as there are some scammers using private.messges for other put instead of helping
For your hotspot problem, first can you use the data without problem?
If so, check APN again. There might be a bit more work than simply updating. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
11-14-2024 05:54 AM
hi @MarcoRossi
you asked others to respond on the forum please. Did anyone try to private message you? would you mind to share more details?
for PM authorization code, you can try to check mark on the box for Trusted device and the system will ask you for the code less
for your hotspot problem. Your laptop still not able to see your SSID? Are try trying to hotspot on the 2.4 or 5.8 GHz? please share the screenshot of the hotspot setting on your phone as well as the APN settings
11-14-2024 03:40 AM
I appreciate that people are willing to answer my question, but many are responding via PM. Is this a tradition or common practice on this forum? However, using PM requires verification codes every time, which is cumbersome, and others cannot benefit from the answers. Respond on the forum instead please.
I have tried adding 'DUN,' but it hasn't worked.
11-13-2024 04:23 AM
hi @RavingRaven
OP not sees the SSID at all on the laptop, so, it is not a problem with APN yet. If it is APN, OP should see the SSID and just have cannot access internet
11-13-2024 04:21 AM
Try the APN settings in this thread....
11-13-2024 04:12 AM
hi @MarcoRossi First, PM does not block hotspot
and that fact that your laptop does not see the SSID was the hotspot setup was not done properly
can you post screenshot of the mobile hotspot screen on your phone?
