08-18-2022 01:38 AM
Title,
Currently I'm on the old reward system using $25/monthy plan, I get $6 off my monthly plan.
$2 off from autopay
$3 off from loyalty
$1 off from referral
This means every year I essentially get $72 off or 72 points.
The new system gives
5 points for welcom bonus,
40 points for loyalty,
1 point per month for referral,
1.25 points for cash back and
10 for anniversary.
Aside from the one time welcome bonus and one time loyalty bonus that's only 37 points per year? Am I missing something?
08-21-2022 10:43 PM
I was on the $25 plan when the points system came out. I calculated that if I switched to the points system then it would be better for the 1st roughly 18 months because of the one time points bonuses. Meaning, if I thought that I would switch carriers within 18 months then it would be better to switch to points.
But otherwise, we all agree. The points system is inferior. I didn't calculate community rewards since I believe both systems award the same dollar value.
Having said that, the points system probably means PM is still cheaper than Lucky or Chatr, since you can redeem each point for $1 off your bill. I haven't calculated how much better it is if you have a much higher cost plan, but I have my doubts.
08-18-2022 12:08 PM
Old is gold! 😊
08-18-2022 10:04 AM - edited 08-18-2022 10:04 AM
'Why should I switch to public points rewards program?'
Nobody is forcing you to switch. Read all pros and cons old vs. new rewards in this forum and make informed decision. Remember - if you switch there is no coming back.
08-18-2022 06:33 AM
Nothing is tempting me to the Public Points new system.
But for new activations, it is better than nothing.
Did you enter a comparison in the excel calculator found at the bottom of this announcement?
08-18-2022 02:03 AM
The old one is better Imo
08-18-2022 01:50 AM - edited 08-18-2022 01:51 AM
keep the old rewards much better if you change to new rewards no option to return back to old rewards,
but you can review this Money Rewards System or go with Points
08-18-2022 01:49 AM
@tonyh98 wrote:Title,
$2 off from autopay
$3 off from loyalty
10 for anniversary.
You stated that it doesn't seem as good as the old rewards system. That's because it isn't. I'll say that if the points sytem was originally in place, customers probably wouldn't think so negatively about it. However, Public Mobile made the new system much worse. The loss of the loyalty rewards far negates the bonus welecome points, loyalty points, and percentage of spend points. As for the contests, I'm not a fan of spending money (points) and receiving nothing in return which is what happens to the vast majority of conetest entrants.
08-18-2022 01:41 AM
Nope. Don't switch.
