12-17-2023 12:08 AM
12-17-2023 11:14 AM
Is it possible that you have an antenna issue with your phone? And I believe @koen is no longer available.
12-17-2023 02:20 AM
Public Mobile wouldn't be the issue if you are dropping your WIFI as you don't need to have a data plan to connect to wifi. Where are you in your house compared to your router? For cell data I know in my basement which is half below grade there are some places I have low reception and data. Could this be the same for you?
12-17-2023 12:19 AM - edited 12-17-2023 12:24 AM
just to clarify, you might have tagged the wrong person, @koen is not a CS agent for PM.
For data usage, it said no wifi, any chance your mobile data is not enabled and hence the phone was trying to use wifi
And check if you have data limiter enabled, could be what blocking the mobile data from working
12-17-2023 12:12 AM
And I’ll add it’s not that I ran out of data. It happens all the time.
