Who provides network coverage for Public Mobile?
Amslak
Hi all,
I'm wondering which company provides data and cell services to Public Mobile.
I've head of cell providers using other company's networks and cell towers. Does anyone know who's Public Mobile uses?
Thanks 🙂
16 REPLIES 16
@Nezgar
I keep forgetting about Sasktel!
@Anonymous wrote:
Public Mobile uses the Telus Mobility LTE network
+ HSPA
And SaskTel's network in Saskatchewan (as does Telus, Koodo, Bell, Virgin, Lucky)
@Anonymous
It's the fine art of adding only the correct info  but all of the info to answer the question.  But not more info than necessary or needed. So @wetcoaster  is on the money....
I often ramble on telling a story.....some appreciate it and others ignore it completely....wall of text notwithstanding.!😁
Self editing....you'll get there eventually. There is already a marked improvement.....don't get discouraged we all learn as we go !!
@Anonymous wrote:
@srlawren wrote:
@Anonymous wrote:
@computergeek541 wrote:
@Anonymous wrote:
@Amslak
Network. Public Mobile uses the Telus Mobility LTE network.
Parent: Telus
visit  Here  for more info.
Public Mobile also uses the Telus HSPA network.
@computergeek541
yeah but i put it a link has all info about public mobile.
@Anonymous yeah but you only bothered to mention the LTE network.  So if anyone didn't click though your "Here" link and bother to read the Wikipedia article, they might remain misinformed.
@srlawren
so for next time when i do posting i have to put it  "Here" link... that you mean to them know about ,, may i right , or what i will do so sorry i didn't getting you !
Or you could just go and add complete information to your post with 9 more characters  ("and HSPA")?
The link might be helpful, but a lot of people asking questions like this are just looking for a short, accurate and complete answer "directly from the provider" - otherwise they might have asked Google / Wikipedia themselves...
@srlawren wrote:
@Anonymous wrote:
@Amslak
Parent: Telus
@computergeek541
@srlawren
srlawren
@Anonymous wrote:
@Amslak
Parent: Telus
@computergeek541
@Anonymous wrote:
@Amslak
Parent: Telus
@computergeek541
@Anonymous wrote:
@Amslak
Parent: Telus
@Amslak
Public Mobile is owned by Telus a such it uses the Telus network. The nicknamed "Bellus" network comes from the sharing agreement between Bell and Telus to provide the most comprehensive cellular network nationwide where Bell towers dominate in the east and Telus towers in the West. This way you will connect to either providers network depending on the strength of the signal.
Whether you are with Telus , Koodo or PM you get the same access to the network. The primary difference between PM and the other two is currently PM does not provide voLTE calling and instead uses the 3G network for voice calling switching from the 4G LTE network whenever you make or recieve a phone call.
However if you force your phone to use 3G only you can use all 3 services in that network ....calling, texting and data. Data in fact will be faster(up to 20+mbps but averaging 12mbps) it will have more latency depending on network traffic. Some users choose this option when the throttled to 3mbps 4G LTE network proves to be too slow for the task at hand.
BlueB
@Amslak
Public Mobile is owned by Telus and operates as a third-tier provider.  As such, it uses Telus' network, which is essentially Telus' towers with some of Bell's towers mixed in depending on the area (and agreements in place).
Is there a particular reason why you ask?  We may have further details depending on what you're looking for. 🙂
@Amslak
Parent: Telus
hairbag1
@Amslak...in the west...PM relys heavily on Telus. In central Canada, Bell / Telus.
@Amslak PM uses both Bell and Telus towers.
Amslak
Oh, I see
Do they use any of Telus's network or only Bell?
JK8
@Amslak
Telus owns PM and they also use Bell towers.
