03-29-2023 05:35 PM
I live in oshawa Ontario my calls are choppy people are telling me I'm cutting in and out data on 4g is like 3g at times if Telus don't fix the service I'll move on I need service
04-02-2023 05:02 AM
No VoLTE yes it's on LTE
03-30-2023 07:20 PM
Can you go to your Settings, then About Phone, Sim Status, Mobile Voice Network Type: LTE?
Also on your phone dial pad punch in *#*#INFO#*#*. Check Phone information and scroll down to see if VoLTE has been provisioned on your phone yet.
03-30-2023 04:09 AM
I'm on 4g I have a pixel 5 it just started not long ago it's set to lte
03-29-2023 07:18 PM
You can also try toggling airplane mode on/off. This will give you a new connection to the network.
03-29-2023 07:16 PM
OK
Telling us you're gonna leave is of no use @cannonman55
We're just other customers like you - we have no skin in the game.
If the problem persists after the recommendations made, let the Customer Support Agents know. Perhaps they can reprovision your account/SIM.
03-29-2023 07:01 PM
Public mobile uses Telus or Bell cell towers so coverage across Canada is usually good.
Has your service always been like that? ie. choppy and data issues? Or just a recent issue.
Which model phone?
A few basic trouble shooting advice:
Rebooting your phone.
Try your SIM card in another working phone. To see whether hardware/phone issue versus PM service problem.
Network reset of phone.
03-29-2023 06:36 PM
1) Which plan are you on? Is it a 4G plan?
2) Is your preferred network set to Auto or LTE (on your device)? If it's set to 3G, change that.
3) Do you know if your line has been upgraded to VoLTE yet?
