04-01-2023 08:37 PM
Account is up to date , can receive and send texts but calls come up as failed . Took sim card out tried in a different phone not able to make calls ? Did all the troubleshooting steps nothing worked , any help would be greatly appreciated !
07-27-2025 07:50 PM
Same thing here. For 3 days I’ve been trying to get help and nothing. I can’t make calls or receive calls. Public mobile is a waste of time. I will be finding another provider when I get home tomorrow
04-02-2023 04:00 AM
Same thing happened to me recently. Turning off/on phone didn’t do anything, but turning on and then off airplane mode surprisingly fixed the issue for me. Only problem I now have is I have to dial 1 in front of every number, including local calls. Seems to be an issue with VoLTE.
04-01-2023 11:06 PM - edited 04-01-2023 11:11 PM
Have you turned your phone off completely (not reboot), wait 2 minutes, then turn it back on? I had a similar situation with my Pixel phone that a reboot didn't resolve. Only turning it off solved the problem.
04-01-2023 08:59 PM
Hi @HALIMACS I think it is that they are enabling VoLTE and broke the voice. Look like common issue these days
04-01-2023 08:54 PM
Please do let us know what they do.
I expect they'll reprovision the account - hopefully that'll help the issue.
They may also enable VoLTE which may assist.
04-01-2023 08:48 PM
Thank you will do !
04-01-2023 08:42 PM
Hi @Badlandsblake I think you tried what you can. And it didn't work in another area,?
time to submit ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
04-01-2023 08:40 PM
you should raise this issue with the customer support agents
Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
