We lost email address
davewendy
How can I reset email address
11 REPLIES 11
Tsawwassen
@davewendy wrote:
I am waiting for a reply cs agent      Thanks
That's the easiest and most efficient way - good luck.
davewendy
@davewendy- It would be helpful to get some updates from you...but further to the above, unfortunately, if your account is suspended and you have the 2FA setting on in the account profile then you wouldn't be able to verify yourself via the registered email address. Which might be what you're up against.
HALIMACS
If by lost the email, @davewendy , you mean you no longer have access to the associated email account, you don’t need it.
The email address to access self serve here at Public Mobile is simply a username. It need not be associated with an active email account.
You should still be able to access self-serve with the defunct email address and password you’ve always been able to.
@Tsawwassen wrote:
Go to your Community account settings and there find the email on file - that is also your account and rewards login email.
@Tsawwassen - this is not true.
People can have different emails connected to their Community accounts as they have set up for their My Account/My Rewards account. These are two separate sets of login credentials.
That would only be the case if the customer used the same e-mail addresss in both places. There's no requirement for members to use the same e-mail address as that used for the Self Serve account.
Tsawwassen
HI @davewendy   If "lost email address" means you have no access to the email address you setup for My Account access, then  get a new email address first.
Open ticket with CS agent and they will change it to the new email address for you
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
WolverineCaz
I suggest the chat bot since i've had good luck there:
@davewendy  PM support can change the email address used on My Account for you.  Please engage them here:
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
@davewendy  You need support help to change email
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
