08-18-2022 04:42 PM
08-18-2022 06:26 PM
@Timer wrote:How To Use Voicemail Features (publicmobile.ca)
Unfortunately, none of the informatoin you have linked to would help the customer as the customer can't even get into the voicemail acccount because the password isn't being accepted.
08-18-2022 05:19 PM
08-18-2022 05:00 PM
@Anna-942 hi ok does it work for you now or can we help you with something?
08-18-2022 04:59 PM
@Anna-942 any chance you were playing with the Voicemail settings on My Account and you clicked Reset?
Anyway, if you go back to VM again, did it ask you to change pwd again? If it is not asking again, I think it is ok
08-18-2022 04:44 PM
OK... so were you able to access your vmail after changing password?
