11-19-2024
11:39 AM
11-23-2024
08:47 PM
Dunkman
Hi. Tried to reset voicemail password, initiated reset, the promised temporary voicemail password was not received, now can't access voicemail. Any suggestions how to fix?
thanks.
11-19-2024 11:44 AM
try to do a voicemail reset once more time on My account. But if you still can't , ask PM to help.
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
11-19-2024 11:43 AM
HI @Daper55
did you press and hold 1 to access voicemail but you no longer able to reach voicemail from your phone?
try to call voicmeial using the 10 digits number 647-580-4001 and see if you can access voicemail that way with the new password
11-19-2024 11:41 AM
If all-else fails submit ticket with support using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
