11-19-2024
11:37 AM
11-20-2024
02:25 AM
computergeek541
11-19-2024 11:50 AM - edited 11-19-2024 12:00 PM
@6048641944 is your user name what I think it is? Probably not a wise idea.
If you want to change it, use the link below to message Public Mobile to change it as you cannot do it yourself.
11-19-2024 11:40 AM
HI @6048641944
if you want your number to come to Public Mobile , you can request that during activation or after
if you already requested , then have you got a text from your old carrier? did you reply Yes ? if you did, reboot your phone with the Public Mobile sim inside and check if inbound calls reach the PM sim card.
or you can also call the porting team to confirm. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
