calls
11-19-2024 12:21 PM
hi
new activation
everything works well however i can not make a call as this part does not work and my signal bars at the top only show half of full with only the top half bottom half not filled in
Service
11-19-2024 12:34 PM
@crushedeagle Reboot the phone first if you haven’t already. Can also try reset network settings too . Also be sure to put 1 infront of the 10 digit contact when making a call and test again if same
submit ticket with support using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
11-19-2024 12:23 PM
half full signal usually is more than enough
but what phone do you have? just want to make sure your phone is fully compatible with PM
and does mobile data works?
since it has issue with calls, could be just sim and account setup problem on the system. Please ask support to help. You can submit by direct message:
