Verification code
Smiley70p
Hello I am having issues getting into my account I forgot my password and had to reset and then because of that it wanted a verification code which is linked to a old phone number I no longer have access too and there is no option to change it or to speak with an agent any help would be great
1 REPLY 1
slusagm
check if you can get the code via email.  Click Didn't Receive code or Resend code.  If Send email is there, use it
but if the email option is not there, ask PM to help.
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
