Cannot Access Voicemail
BeeCeeTO
When I followed the prompts to reset my voicemail pin the system said it would send a temp pin via sms but I never received it. When I logged into my account I click on edit voicemail password. It tells me to call my own number and follow the prompts to reset my password but the voicemail system asks for my pin when I try to do that.
Help!
Brian
1 REPLY 1
@BeeCeeTO were you able to receive text or other 2FA text??
you might want to ask support to reset the voicemail account for you instead
open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
