11-18-2024 12:25 PM
I have rebooted my phone and I was expecting to see Public Mobile cellular service instead I am getting SOS. Can you Please fix the issue ASAP.
11-18-2024 03:41 PM
hi @DRPatel no, you can get it today
you can get a Public Mobile sim card from Telus or Koodo store or via Amazon (remember to ask support to reimburse)
Telus or Koodo store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
Then message support agent and ask them to help to update your account with the new sim card:
11-18-2024 03:32 PM
do I wait for days to get physical sim and stay without phone service?!?
11-18-2024 03:28 PM
hi @DRPatel since you have a ticket with support agent, best to work with them on a solution
they might help you to get a new eSIM (or push them for that) or they might ask you to go physical sim for a quicker fix.
11-18-2024 02:44 PM
It’s been really frustrating experience so far. First agent, give me the phone number and asked me to unplug existing SIM and see if my phone works with the ESIM and the new phone number. Which is the right Approach. That agent was out of office and so other agent asked me for the account number of the existing Provider to move phone number. Now phone number has been moved, but my phone still do not have a Public Mobile network. It’s in SOS only. They are asking phone model after moving the phone number. Is it fair?
11-18-2024 12:43 PM
@DRPatel No worries support can help fix this for you
11-18-2024 12:40 PM
hi @DRPatel
this is not a problem with porting, your porting should be done
your issue is about the sim card not properly setup on the system yet. Support agent can help. You can simply message them by direct message:
