03-20-2023 06:28 PM
03-28-2023
06:55 AM
03-30-2023
04:03 PM
Luddite
Have performed hard resets, network resets etc. PM tech confirmed it is an issue with IOS 16.3.1. Waiting for next Apple software update to resolve.
[time will tell I guess ..... Luddite ]
03-21-2023 10:05 AM
@Mjk - is your issue similar to this one?
https://productioncommunity.publicmobile.ca/t5/Get-Support/Voicemail-notification-stuck/m-p/955960
03-20-2023 08:21 PM
My voicemail indicators and notifications have never worked consistently on Public with iPhone. They worked fine when I used Telus. I've gone through all the trouble shooting steps before with no resolution. Things are intermittent at best, although lately they have been working.
03-20-2023 06:30 PM
It is your phone feature, nothing to do with PM.
Reboot your phone (turn it off, wait a bit, turn it on).
When this issue started? Maybe you need to hard reset your phone to factory spec.
