No service after porting number
rshomanti
I ported my number to Public Mobile almost 2hrs ago and I'm having issues with no service. The self serve page says status is active and my previous carrier already closed my account with them. I tried all of the troubleshooting options provided through the chat bot but none of them worked. I even updated my APN settings. Still nothing. Did my number just not finish porting yet or is there something else going on?
Edit: Also when I go to edit SIM, it shows this.
rshomanti
Yeah, I've been in contact with support. They said it should hopefully be fixed by afternoon today. Thanks.
@rshomanti
you have another phone to test the sim card?
And no worry, it should be just a sim card provisioning issue.  It is an easy fix for PM, you just need to engage them :
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
@rshomanti  Did you reboot the phone ? Did you reply YES to the confirmation text from old provider ?
