I need an CS_Agent to reset my password.
EChiu
Due to some issue, I cannot reset my password. I would need an CS_Agent to help reset for me.
HI @EChiu
if you are unable to receive the reset password email, maybe you cannot access that email, you can submit a ticket for CS agent to reset the password for you and help to change the email address if needed
Please submit ticket at : https://publicmobile.ca/chatbot.
First type Forgot Login,
Dunkman
@EChiu
CSA will take up to a few hours to respond.
This website is finicky.  You can try a different web browser, clear cache or incognito mode.  Or even try to reset password on a different device.
@EChiu  Here’s how to get support
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
