Plan cancelled without notice
Paseo
Hi,
My plan was cancelled because I didn't update my credit card number. Now, I have no service at all and when I sign in into my account it forces me to choose another plan (off course...more expensive) and there's no way that I can access my profile to update my credit card. I don't want to loose my number and my plan. Please, somebody explain me what I can do?
Thanks
Paseo
Thanks to everyone. Super fast and helpful community here. Thank you again.
hairbag1
@Paseo
if you're stuck; you can use Public Mobile payment vouchers you can get from Canada Tire, No Thrills or Shoppers...then dial 611 to add them to your account and Resume service. Then get Customer Support to fix the main issue.
hi @Paseo
you are just having 2 different problems
first, PM is a prepaid service and service will be suspended if there is any autopay disruption. Usually you just need to login the account and pay
but unfortunately, you have trouble login the account.  Ask PM support agent to help.
you can still submit  ticket by direct message:
slusagm
no worry, your account still here, what you see is a login problem.
you can ask PM to fix the login problem first and then pay to resume service
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
