02-16-2022 06:41 PM
I’ve been having an issue with trying to access my voicemail for about a month, I don’t get many calls and when I do normally they don’t leave voicemails so it hasn’t been an issue. However I always get this error message when I call my voicemail and cannot get through there is no dial tone and fails everytime.
02-17-2022 07:50 AM
Lol....phones need shut eye too! Try to give your phone a little down time once a week. If you hit the sack early on Sundays for example let your phone do the same thing or if you sleep late on Saturdays remind yourself to let your phone have a lie in too....
You will be surprised how much happier your phone will be!
To pre-verify your account include your full name, address, email, phone # and 4 digit acct pin
02-16-2022 06:54 PM
Thank you, all it took was restarting my phone. I never think to do that and it fixes most issues I’ve had
02-16-2022 06:53 PM
You may need to update the voicemail number stored on your phone.
Check the list from this thread here.
Choose the number closest to your location, and edit it into your VM settings.
02-16-2022 06:52 PM
Did you ever had access to your vmail?
Have you set it up very fist time?
Can you access it calling it from another phone?
02-16-2022 06:45 PM
reset SIM, take out SIM, re-inserting SIM and power on,
try toggling airplane mode off/on,
and Rebooting device..test it.
02-16-2022 06:42 PM
Hi @Samantha90
try to call your number from your phone,
