Voice Mail
bobarama
Hello !
On my iPhone it says I have 5 messages but I do not have any ! Who could correct this and have the cellphone show 0 messages ??
17 REPLIES 17
bobarama
I am running iPhone XR
It is running IOS 17.2.1
I will try this…Thanks
@bobarama   Earlier on in this thread I asked  "If you are pressing 1 or dialing your number for voicemail, try instead tapping the voicemail symbol in the phone app which takes you to Live Voicemail if enabled."
Did you try this?   What iPhone do you have and is it running ios17?
bobarama
I have closed down my iPhone and also took out my sim for hours but the showing of 5 messages is still there !
einsteinbqat
@bobarama  It might happens sometimes. Just restart the iPhone. It normally should go away.
bobarama
Wiping out my iPhone is not at all worth my little problem !
Whiskeyruncrew
Fair point 👍
@Whiskeyruncrew Maybe worth doing a factory rest and rest all settings
Factory reset would be a last resort for a problem since it will wipe the phone.  Hopefully we're not quite there yet!
Whiskeyruncrew
@bobarama   If you are pressing 1 or dialing your number for voicemail, try instead tapping the voicemail symbol in the phone app which takes you to Live Voicemail if enabled.
@bobarama
it could be a live voicemail issue.  Someone enabled it back and able to find the "missing" VM back, check this
https://productioncommunity.publicmobile.ca/t5/Get-Support/Voicemail-Problems/m-p/1132993/highlight/...
bobarama
Tried both and not successful !
bobarama
I do not know ! !
bobarama
Yes !
Whiskeyruncrew
Have you tried a soft or hard reset to your iPhone ?
Phil_Adelphus
@bobarama   Is it possible they are in Apple's Live Voicemail and not the PM Voicemail?
Chalupa_Batman
Hey @bobarama
It happen to me on my iPhone. You have to reach out to a CS Agent and ask them to reset your network from there end. You may be required to turn off your phone for a bit till it takes.
Yummy
It could be apple issue particularly if you use imessage.
Did you try to reboot your phone (turn off, wait a bit, turn it on)? Remove SIM, wait a bit, push it back, reboot?
