12-10-2022 04:30 AM - last edited on 12-10-2022 04:46 AM by computergeek541
Who thought it was a smart idea to get rid of customer service lines?! I changed pass and still cant login to my account. Useless im about to switch to telus where i know customer service still exists.
12-10-2022 07:53 AM
@suicidal-hime I can relate to your frustration. I'm glad I was able to handle it. After things are setup, there's actually relatively little intervention required. Either way, dealing with a Customer Service Agent has been very helpful for me.
If you require assistance and would like to deal with a person, the easiest is to contact a Customer Service Agent @CS_Agent
Here are their published steps too:
12-10-2022 07:21 AM
violation of terms of service/inappropriate content
12-10-2022 06:51 AM
@suicidal-hime wrote:Who thought it was a smart idea to get rid of customer service lines?! I changed pass and still cant login to my account. Useless im about to switch to telus where i know customer service still exists.
Since PM website has caches issue, so clear caches , cookies then using computer and private or incognito mode browser to login. For some mysteriously reasons, mobile device some times hard to login.
If still keep saying your email and password was wrong, then open a ticket with PM customer service for help, https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
12-10-2022 06:03 AM
Clear your system cache and cookies, then open an incognito tab and try logging in again.
If you continue to have issues, use the reset password feature again to ensure you are reentering the correct password.
If you are still having issues accessing self-serve, the only method to contact customer support is as follows:
There are 2 methods:
12-10-2022 05:03 AM
Try logging into your account using a browser in incognito or private mode and try again.
This website has terrible caching issues.
