Referral Reward
wendykcw
On Friday, 2 December I referred my husband to Public Mobile with referral code given. However, up until now, I don’t see the reward showing up my account ( $2 off from my bill and my husband’s bill) Also, my husband and myself should get an additional $10 each.
7 REPLIES 7
yackinlyn
FYI we signed second line on the 4th, missing reward just like you, I contacted them, gladly to see the $1 reward was added to the refering accounts, waiting the $10 for the refered account now, please contact the agent, they are quite prompt to reply your PM. make sure you remember your community PIN.
@wendykcw
Depending if you are on the old Rewards system or the new Points system (activate your SIM after January 25, 2022).
Only your husband will receive the $10 credit on his second bill but you will receive $1/month (Rewards system) or 1point/month (Points system)
Also, the $2/month credit only applies to members on the old Rewards system for using AutoPay but will only receive 5% in points (Point system) on your monthly payment.
yackinlyn
that happened to me on the 4th. hopefully they can fix this.
Quigley
Looks like the referral gliche is still around.   That's just terrible.
yackinlyn
yes I did the same thing to my husband on the Dec 4, and no rewards so far, so i contacted the agent, he said he didnot see my refer code entered which is weird.  the refered person can contact them and add manually. i just received a message to confrm this. will be within 72 hours.
hubby did get 5 points
Quigley
@wendykcw
You as the referer will  get the $1 rewards per month, while your husband as the refered will only get the one time $10 bonus credit.    Sorry but you don't get the $10 bonus credit.
Edit...
Since you refered your husband before December 12, you'll both be getting the promotional $5 x 5 months RAF credit as well 😊.      The first $5 RAF credit will be paid in the first week of January, so look for that credit.
Yummy
Are you on old rewards? If yes you will get $1 off on next renewal.
Why do you expect your husband to get ANY $ off?
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
