12-28-2024
06:46 PM
01-01-2025
12:40 PM
Dunkman
Newly joined PM here. It was showing <2gb used in last 2 weeks but received data used 70% already today!! Checked website again & found used 4.5gb in one day?? Can't believe such big difference in few days....
12-28-2024 07:01 PM
@RaeC Might be cace issue check again with. New web browser window and use incognito mode / private mode or from another device . Can even uninstall the app and re install it and check again
12-28-2024 07:00 PM
in phones settings, disable data to apps you don't use on a regular basis. Also, disable wifi assist.
