04-06-2023
04:42 PM
04-06-2023
05:07 PM
computergeek541
What will the data speeds be for USA roaming? Will it be the same speed as in my current plan?
04-07-2023 12:57 PM
@hycm53- Thanks for the update. And that's with volte which was the real part of your test. So still no AT&T.
By the way, any modern phone can all 911 without even a sim in the phone. Or an expired sim. Or a sim that won't connect to a network.
04-07-2023 10:03 AM
It looks like for emergency call only when connected to AT&T.
04-07-2023 09:58 AM
@hycm53 thanks for testing, still a no go for AT&T ;(
04-07-2023 09:55 AM
After I manually connected to AT&T, “SOS” showed on screen. My phone is iPhone 8 Plus. It automatically connected to T- Mobile.
04-06-2023 08:06 PM
Lots of factors to consider, including local network capacity and congestion, as well as your plan speed at home. Keep in mind that when roaming I believe there is some sort of a connection back to your home network (sort of like a VPN), so that will add lag.
04-06-2023 07:49 PM - edited 04-06-2023 07:50 PM
Depending on your plan....if it's "3G" then it's throttled up to 3mbps. If it's a "4G" plan then it depends on the provider. Currently it's only been proven that we can connect to T-Mobile's 4G LTE network worldwide mobile data. Typical download speeds are between 19 and 76mbps and upload speeds of between 4 and 20mbps.
04-06-2023 05:01 PM
@dust2dust wrote:@hycm53- And remember to try the connection to AT&T. 🙂
Yes, sir!
04-06-2023 04:55 PM
The speed is decided by the fact that the data flows through Telus/Public routers via the APN.
04-06-2023 04:49 PM
That would be great thanks
04-06-2023 04:49 PM
@Ckk_2194 Yes, as good as you have it here, maybe better
04-06-2023 04:48 PM
04-06-2023 04:46 PM
@Ckk_2194 wrote:What will the data speeds be for USA roaming? Will it be the same speed as in my current plan?
I will test it when I'm in the State tomorrow.
04-06-2023 04:46 PM - edited 04-06-2023 04:46 PM
It will be 4G/LTE if you are on the 4G plan and if your phone is compatible.
04-06-2023 04:44 PM
Yes...theoretically.
04-06-2023 04:43 PM
Yes.
