10-12-2026 12:22 PM
how much to use roaming in Japan? Any discount if I get the roaming for a full month?
10-12-2026 01:12 PM
thnks for the list. I have TD, I never always they have that app, I will try it
10-12-2026 12:57 PM
yes, no roaming in Japan and hence you won't be able to receive 2FA text when you are there
All banks offers other ways to receive 2FA such as:
Check with your bank to see if you can change the 2FA the one that suit your need. Anything that allows access with local Wifi or local data will work
10-12-2026 12:50 PM
@Seeiy wrote:but I cannot get the bank code using travel some right?
That's correct. You should call your bank to see if they can send 2FA to your email instead of your cell.
10-12-2026 12:48 PM
10-12-2026 12:27 PM
You CANNOT use PM services in Japan or ANYWHERE else outside of this continent.
10-12-2026 12:27 PM
sorry, PM does NOT have roaming services in Japan. In fact, PM only has roaming in US and Mexico and nowhere else
For data while you traveling, you will have to use local data sim or travel eSIM such as Airalo.
For voice calls and SMS from friends, you can download VoIP app TextNow and use the app for that. Make sure you setup TextNow before your trip. You can even forward voice calls to the number provided by TextNow right before you leave Canada
For RCS and iMessage, you can still send receive them with local data or Wifi. But remember to enable PM sim and turn on Roaming for iMessage and RCS to work (the actual roaming services won't work, but enabling the sim and roaming allows iMessage/RCS to validate your phone number)
But if you are expecting 2FA from banks/email/businesses , you won't receive them while you travel without roaming. You will need to arrange to change to receive via email or app ahead of your trip
10-12-2026 12:26 PM
Sorry, no roaming option in Japan at all
10-12-2026 12:24 PM - edited 10-12-2026 12:26 PM
Public Mobile has no roaming options outside of Mexico or USA. You'd need to get a travel sim from airlo or someone else for use in Japan.
added...here's a link to view their offerings...
