Urgent
Masouda1
I lost my email and now what should I do to reactivate the sim card? I was supposed to activate it every month on the 5th but this time it's the 6th and I still haven't solved my email problem. What should I do?
HI @Masouda1  open ticket with CS agent and they can help to change your email address for My Account and help to reset password
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
Meow
Contact agent to update/change your email. Only they can do that.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
@Masouda1  did you try to use the Reset Password link there to reset the password?
If that still does not work, then open ticket with PM support using Charbot and they will sort it out for you
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
@Masouda1 @To change email you need supports help
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
