01-06-2023 10:32 AM
The Data Usage on My Account page says I have 0 GB remaining of my 15 GB plan. I also received a text message saying I've used 100% of my data - however when I look through my usage history and add up all of the data used for this billing period it's only ~7.5 GB.
01-06-2023 10:50 AM - edited 01-06-2023 10:50 AM
@publicmobileus3 wrote:
I exported my plans usage to an .xls file and added all my data usage for the billing period and it only adds up to half (7.5GB of my 15 GB limit)
@publicmobileus3 and you confirmed the cycle start date from My Account and start adding from the correct date? Cycle start date will change, not start on the 1st or not start on the same date every month
if you added from the correct date and still there is discrepancy, please open ticket with PM Support and have them to further investigate:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
01-06-2023 10:48 AM
@publicmobileus3 and for your usage add up issue, there is a glitch on the Usage page if you just filter data there :
if you want to confirm the usage, please download the usage history in xls and then filter and sum up using Excel
Also, make sure you aware that cycle start date changes all the time, so, on My Account, make note of the current cycle start date and add up the data usage from that date
01-06-2023 10:45 AM - edited 01-06-2023 10:46 AM
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
01-06-2023 10:44 AM
@softech @Handy1 I opened My Account incognito mode (in an entirely separate browser Chrome -> Firefox). Same issue persists. I also tried refreshing the page as suggested.
01-06-2023 10:36 AM
@publicmobileus3 the text could be correct, bust that the My Accoint page yiu reading earlier was cached, not providing correct usage info
An easy way get thr correct info is to click the Spinner on the bottom right of the section to force a refresh.
If you don't see an updated usage still, try to login My Account using Incognito mode (or InPrivate for Edge, Private for Safari) or try again with a completely different browser like Edge/Firefox/Chrome or try on another device. You should then see the latest info from the server.
01-06-2023 10:33 AM
@publicmobileus3 @Try loggin in again incognito mode there are cache issues or refresh page once logged in again
Refresh page. ^^^
