3 hours ago
As regards the $ 34/ month 5G plan - Does "Unlimited Canada and US wide minutes" include unlimited calling and texting both incoming and outgoing, right?
3 hours ago
Yes, calling, texting and data will work in both countries whether you are sending or receiving calls or texts.
3 hours ago
Hey @Dewana
I had this plan recently and it's as if you were at home. Unlimited calling/texting from anywhere in Canada and the US. You can also use your 50GB of data down there too if you wanted. I did a lot of FaceTime down there. Great plan to have.
3 hours ago
Correct.
Whether you are in Canada or the United States. You should have unlimited incoming and outgoing talk and text.
