No phone calls in or out
11-03-2024 07:21 AM
Signed up for canada-us unlimited phone, text, messaging etc., worked fine in Canada, since in US no access to phone calls, sending or receiving.
Phones
11-03-2024 09:49 AM
A work around if you dont have a volte enabled phone that is on PM whitelist is download a voio app like textnow. Pick a phone # for free and use that to make phone calls. Use your data and text as usual like in Canada.
11-03-2024 07:39 AM - edited 11-03-2024 07:40 AM
@aljjenks Do you have data roaming turned on in phone settings ? Also set phone to 4G/LTE not 5G and make sure your connecting to T mobile AT&T or Verizon
also check the PM
voLTE white list if your phone not in the list you won’t be able to make voice calls in the U.S.
VoLTE white list
