02-25-2025 05:04 PM
I am unable to receive any calls on my phone. Outgoing calls are not a problem. I have rebooted the phone several times and confirmed ringer is on. Also tried a Telus and Koodo sim card in phone and had no issues. Replaced sim card on spec and still have the same issue. Also unable to receive alerts when someone leaves a voice message. Using a Telus and Koodo sim the message alerts are sent to my phone. Phone appears to work properly, issue appears to be a network issue and a need a Customer Support Rep to assist.
02-25-2025 07:11 PM
hi @Sisu60
if you are around Kamloops, BC, then there is active outage at the moment
02-25-2025 05:46 PM
HI @Sisu60
there have been many posts about voice and text in the last 2 days. May I know what phone do you have and what area you are in?
but try reboot the phone, try Reset Network Settings and try your sim card on another phone
02-25-2025 05:09 PM
PM and Koodo works on Telus network so I don’t think that is an issue.
Did you port a number over from another carrier? This seems to be an issue with recent porting.
If you are a longtime member. Best to contact a CS_Agent to investigate the issue.
