no data service
binbin79
I just ported my number in, there is no data service now. Could yu check why?
HI @binbin79
what phone do you have?
and where you are?  if you are around Kamloops, then there is active outage at the moment
https://productioncommunity.publicmobile.ca/t5/Get-Support/Outage-Alert-Mobile-Data-and-Voice-for-Ka...
binbin79
it is too complicated. I restarted my phone, still no data service.
hi @binbin79
try Reset Network settings and see if it works
and check APN settings if you have an Android
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
