02-01-2023 02:53 PM
I have a voice mail that's about 45 seconds long I listened to it and saved it.
I wanted to listen to it again: as prompted, I pressed 1. But it plays only a small fraction of a second of noise and stops. Then goes to "To listen to this message, press one". Basically the playback is blank/truncated.
This is the second time it has happened.
02-01-2023 03:25 PM
Hi @Kazinator so, it happened before already? Since it is not an one odd case, you should open ticket with CS agent and have them to reset the VM for you
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
02-01-2023 03:11 PM
@Kazinator - strange.
Try restarting your phone see if that helps. Also, i'd recommend a reset of the device's network settings; odd how doing this sometimes fixes finicky things (even with voicemail issues).
You could try the SIM card into another phone and see if you can hear the message that way.
02-01-2023 02:55 PM
@Kazinator Try to call from a landline to see if it makes any difference
Not sure if PM support can really help on that, but I guess if nothing work, you do need to engage them
