02-01-2023
10:21 AM
02-01-2023
05:33 PM
computergeek541
I just switched from Fido and am wondering if there's a difference in the audio and mic quality, particularly VoLTE?
02-01-2023 03:01 PM
There isn't a huge difference I find. The audio is difference is negligible in my honest opinion. You won't hear any differences.
02-01-2023 10:33 AM
@nethan there is no VoLTE here 😞 not yet
But maybe it will come soon
I have used Rogers and PM , can't tell the difference from the ear, but since PM only using 3G for voice, I would expect there is indeed technical differences, but maybe so minor and ignorable?
02-01-2023 10:28 AM
@nethan voice works great for me no issues at all , I think you made a wise choice by switching to public mobile !
02-01-2023 10:28 AM
Public mobile does not utilize VoLTE as of yet.
However, with the eventual roll down of the 3G networks, it may only be a matter of time.
I can say that having been with Bell mobile and Koodo, I see virtually no difference here.
02-01-2023 10:23 AM
@nethan - I can't see any difference between the two of these. It can also depend on the device that is being used, keep in mind.
See helpful info. here for porting over to Public Mobile: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
