Unable to make or receive calls
RJR
I have 2 lines, both auto pay, due today.  Not able to make calls or receive.  Message says make a payment.  What is up, please?
jesimons
Same problem, there are funds on the account and status on the account page says "active" but unable to make/receive calls, tells me my plan has expired. Texts/data working though apparently. Ticket opened yesterday no response yet.
RJR
Thanks, ticket opened, but no answer yet
RJR
Thanks, opened ticket but no answer yet
@RJR
are  your data and text still working?
there was problem with voice calling and receiving for some customers last copule days ago.  The issue supposed to have been fixed, but it is possible that it came back for some users.
Please try Refresh All networks and see if it helps
if not, open ticket with PM support
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
@RJR
Can you try your SIM into another phone? If calls still don't work Turn off VoLTE if you have a VoLTE enabled phone. If that does not work, connect with contact customer service agent for assistance.
Perhaps you are affected by this: https://productioncommunity.publicmobile.ca/t5/Announcements/Resolved-Service-Impacts/td-p/955119
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
