01-23-2025 12:41 PM
I'm unable to get any incoming calls & when I try making a call it says Call Ended.
I've taken the SIM card out & out it back, turned phone off & restarted, still no luck.
Any suggestions would be appreciated.
01-25-2025 03:22 PM
@Phil_Adelphus wrote:@Rosie10 Not having Volt on my phone is the issue. Works ok in Canada but not in the US.S
Yes that'll do it. We didn't know you were in the US.
For that very reason, I have removed the assigned solution as it will cause confusion with some incorrectly thinking that VoLTE is required to use Public Mobile service (even though it isn't).
01-25-2025 02:10 PM
01-25-2025 01:42 PM
01-24-2025 07:21 AM
@98_vbs_ab The phone needs Volte to work.
A non-VoLTE phone will still work for the most part in Canada as we still have 3G networks here for now (although Rogers/Fido/Chatr are shutting theirs down this year). It's in the USA and maybe Mexico (?) where there are VoLTE problems, the USA has not had 3G networks for 2 years now.
01-24-2025 01:22 AM
What type of phone do you have? The phone needs Volte to work. If it's an older handset you might have issues. Please check phone compatibility to make sure.
01-23-2025 01:37 PM
@Rosie10 Have you tried reset network settings? Also try airplane mode on, wait a minute, then turn it off again. If you need to contact customer service open a ticket at the chat icon bottom right of this page.
01-23-2025 01:27 PM
Payment has been going through ok.
01-23-2025 01:25 PM
Mobile data works.
There is no outage, and my service is active.
I just can't get incoming calls & can't call out.
01-23-2025 12:53 PM
log in to your account to make sure it hasn't been suspended....sometimes autopay can fail.
01-23-2025 12:47 PM
hi @Rosie10
does mobile data work?
where is your locatoin? check Telus outage map
https://www.telus.com/en/bc/outages
and check your My Account and see if your service is active or not
