05-23-2022 10:43 AM
For some strange reason I am unable to login to my account to make changes. My CC expired and needs to be updated. When I try logging in it says failed and when I try the forgot password, I enter my email twice but still get an error. I have no idea what to do? The plan is going to expire and the phone service will stop.
05-23-2022 11:03 AM
Contact an agent. Look for reply from envelope icon top right.
05-23-2022 10:45 AM
05-23-2022 10:50 AM
As long as your account is in good standing you should be able to log in.
Try different browser but be aware if you try too many times your account will be locked for 15 minutes before it will let you try again.
If everything fails, contact agent for assistance.
05-23-2022 10:58 AM
Have you ever created a self serve account before @Coltdiamond ?
If not you can register for one here:
https://selfserve.publicmobile.ca/self-registration/
Note - If in nonpay status for over 90 days, then you lost your account, number and access to self serve.
OR,
Were you able to log into self serve previous to this recently?
If so, and after following other suggestions already supplied to you, and still issues submit a ticket to CSA for assistance.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
05-23-2022 10:59 AM
Thanks for your quick reply.
I have tried that many times. Unfortunately I cannot even login to open a support ticket as it does not recognize my email address. I am unsure how I even am able to login to the community. I think I had to create a 2nd login.
05-23-2022 11:03 AM
05-23-2022 11:04 AM - edited 05-23-2022 11:09 AM
@Coltdiamond - well you do seem logged into the community. 🙂
SIMbon Chatbot uses your community credentials to submit a ticket. Then to verify your account you need to have a current self serve account set up. Have you ever logged into self serve successfully?
If, for some reason, your account is disabled then use the 2nd method to submit a ticket in the above link, or below one which is the same to send a Private Message to Public Mobile Customer Support Agents (CSA)
edit
05-23-2022 11:11 AM
I was able to open a ticket with support.
Thanks folks. Hope this gets things resolved.
