Login without access to simcard
Delightdeck
Hi all
I do not have access to my account. Sim card is out of my hand. I cant login. I only have my email for verification.
Thanks
Delightdeck
Delightdeck
Thanks a lot for reply. I just sent message for help. I will update you guys on how it goes.
Delightdeck
@Delightdeck  Do you see option says “didn’t get code “ tap it and you should get option to send code to email and get logged in
Chalupa_Batman
@Delightdeck wrote:
Hi all
Thanks
Delightdeck
If you need help logging into your account, create a ticket for a CD Agent to assist.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
