02-24-2025
05:53 PM
03-08-2025
11:54 AM
Dunkman
Hi there, a friend of mine has many more (and much lower priced) options to change their subscription to than I do... Why is that and how can I get access to the lower priced plans?
02-24-2025 06:00 PM - edited 02-24-2025 06:02 PM
Downgrading (and maybe upgrading) plans is very selective and some customers can see more (or less) plans then the others.
We are considered as ALL equal customers but some are more equal then the others.
02-24-2025 06:00 PM
@SpeedySuperBad wrote:Hi there, a friend of mine has many more (and much lower priced) options to change their subscription to than I do... Why is that and how can I get access to the lower priced plans?
Truthfully @SpeedySuperBad the only way to get one of the current low plans offered is to port out to another provider and port back in. It's a headache and you shouldn't have to do that considering it's a prepaid service.
02-24-2025 05:58 PM
Sorry, PM is setting different plan options based on your profile and you can only change to those that you see
Your friend likely has a lower priced plan and hence he sees more options
02-24-2025 05:56 PM
It is because PM are targeting members with a lower plan. Your friend probably have a lower priced plan than yours. PM are trying to get your friend to hop onto a more expensive plan.
