Unable to login on my chromebook.
bob17
When I try I get, "This page isn't working" auth.telus.com redirected you too many times. Try clearing your cookies. "
  I cleared the cookie but was still getting the same message as above.  Very frustrating .
 Everything was great before this "eversafe " stuff arrived. Please help.
@bob17
If you registered on Eversafe ID and you are posting on this Community then click on the 3 horizontal lines and login to your account.
HI @bob17  but you can login to Community.  Community and My Account now use the same login system,   is that a problem only when trying to access My Account?
@bob17   Chromebook uses Chrome and should be fine.  I am logging in using Chrome and Edge, both work
Try Incognito mode
and since it is a Chromebook, go to the store and try to install the PM app , see if it works better
@bob17  Message support directly
  • while your already here and logged in the community
  • you can send a private message   To CS_Agents by clicking >>>>>>>>here.
