Re: Deleted eSIM - number not working
AntonPotzi
My friend wants to login to his account, but can't get in due to it asking first for code to be sent to email. Then, once that goes thru, wants a 6 digit code from phone number, the number he is unable to use
self solution removed
@AntonPotzi wrote:
How to contact them? Since when I message, it keeps sending me options that don’t help me
hi @AntonPotzi
this  is the easy way to submit ticket
submit  ticket by direct message:
AntonPotzi
hi @AntonPotzi
Just message support agent.  This is a common issue, but support can sort it out
AntonPotzi
I have been waiting for a text message off his phone, but has not received anything, so is unable to login to the account
hi @AntonPotzi
your friend has active service with PM at this time?  the code should sent to his number, what you meant by his number is unable to use?  does he know his voicemail pin? he can click Didn't receive code and select send via voicemail, then wait an hour and call his number from another phone to retreive the voiemail
if that does not help , he can ask support to help.  He can submit  ticket by direct message:
